I finished the user interface software tonight. Screwed the back on the case. There is always something special about being done enough to screw the case together. Now it is time to see what I can see by using it!
A project log for 4 Channel Temperature Logger
A box that reads 4 K type Thermocouples and outputs in CSV format over USB Serial.
