Version 1
A project log for Another man's treasure
Basically a radiator driving a turbine while the turbine that drives a generator and the generator that drives...
ryan-garibayRyan Garibay • 06/21/2018 at 04:56•0 Comments
My first idea was to use a flywheel system that alternated between charging batteries and spinning up the flywheel. by my best estimates it could only extend a battery 30 minutes or so. however this number changed drastically with its load.
