I spent the month of July soldering, So much solder, nights weekends I even took two vacation days just to make sure I had them all done in time. I also learned that if you order a replacement part from Digikey or 1000 of them, within 48 hours of getting your Digikey order, you will get the part that was holding you up from China. Also how many CR2032's can yo order before they put you on a watch list? Asking for a friend.
TechGirl
