Been a while now, it's summer, work at the highest point, available time has gone down for me a little. But not enough to stop me. So why don't you guys have a guide yet? Because I decided to add an element to the pcb, as an option for people that don't have a Netatmo :)
Yes, I added a socket to connect a temperature sensor, I chose the Adafruit MCP9808. You could also pretty easily use the bigger version that has humidity and pressure sensor on it.
I did not yet print this PCB for test but shall do this this week
Psycho
hi this is a fantastic idea. its really spiked my interest and would like to integrate with domoticz. first part is doing the build. Do you have the circuit designs im going to see what the cost of manufacture is.
many thanks
