![](https://cdn.hackaday.io/images/6264351530896238397.jpeg)
Well a filament spool fell off the machine and hit the emergency stop button causing a misprint. Sad times. So I started another print and finished out the last of what was on the white roll. I am out of white so I have switched to silver which is what I have the most of. The second printer is working on 3 cells now and I believe will have enough for another 3 before the roll is too small to use for anything. Otherwise everything is going well. We have 10 cells printed, 13 once I pull the 3 off the printer when I get home.
I know right, when it stopped I was just praying that nothing was broken because there is not enough time in this challenge to be ordering 3d printer parts.
That filament spool has really good aim
