So I have been doing a bit of reading on various materials. There have been studies conducted on earthenware membranes. This was a clever suggestion from Mechanicus. Terra Cotta is one of these. Though I could spend lots of money on custom made film membranes, in the spirit of hackaday I need to HACK something that is both common , repeatable and effective. I believe earth based/ clay membranes would be much better as the cost is less than 10 percent that of a designer membrane from somewhere like fuelcellstore.com for example.
![](https://cdn.hackaday.io/images/2047551533421261278.png)
36 dollars plus tax for 11 sq ft of PEM / Cation Membrane material is a fantastically priced over the designer films
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4744959/
http://www.clays.org/journal/archive/volume%2012/12-1-397.pdf
![](https://cdn.hackaday.io/images/9887231533420600378.png)
![](https://cdn.hackaday.io/images/7466871533420605899.png)
![](https://cdn.hackaday.io/images/202031533420610736.png)
![](https://cdn.hackaday.io/images/5171921533420616965.png)
![](https://cdn.hackaday.io/images/549961533420325693.png)
![](https://cdn.hackaday.io/images/9095441533420342043.png)
![](https://cdn.hackaday.io/images/1677301533420365835.png)
https://www.hindawi.com/journals/tswj/2015/864568/ good article related to my setup
