For the RGB ball we wanted something a little cleaner, more elegant. So we combined the structure and the signal path. The little slots that are soldered together to make the ball also carry the signals and power.
The top cap pass the signal from slice to slice connecting the DOUT from one slice to the DIN of the next. The bottom cap works in a similar manner but is just 5V and GND.
Unfortunately there are still a couple wires in the build. There are user buttons on the bottom cap and some sensors in the top cap that need to be wired. The battery is connected to the power slice by wires and that slice is in turn connected to the power distribution cap (bottom).
Still needs some cleaning up but its getting there.
