I've made a lot of progress on visualizations and setting up the state machine. Now I want to implement power button behavior since it needs to be globally available.
Because there is no hard power switch and the momentary push buttons that wake and sleep the badge are the tallest parts I want a somewhat robust sleep and wake sequence to prevent accidentally turning the badge on and draining the battery. Here is my sketch that I will work on implementing today:
