The data collection begins!
A project log for Harvester - Building the Energy Forest
An Open Source project to build cheap linear generators to harvest the wind energy which moves trees in a forest (or waves in the sea)
tobiwanTobiwan • 09/04/2018 at 14:49•5 Comments
Today I tied a Dyneema fishing rope with 80kg of max draw weight to the big birch in our garden. The birch is around 15m high and the point where the string is attached is at about 8m. The string goes then around two spools, one is attached to a rotary encoder, and to a 300gram weight which gives the string the tension. The data from the rotary encoder is then collected by an Arduino Uno and saved with a timestamp onto a SD card. There are 5 datapoints per second collected. The overview:
The spools are sitting on ballbearings, everything is 3D-printed:
The whole setup is encapsulated in a lunch box and screwed to a wooden plate. The Arduino is connected to a power bank with 10000mAh which should provide power for several days.
Cant wait to see the first data! Unfortunately there is not much wind at the moment.
Jan wrote 10/10/2018 at 14:30 • point
Hey there, have you found any interesting data yet?
Tobiwan wrote 10/20/2018 at 08:13 • point
Hey, sorry it took so long to answer, I was on vacation :) I have two full days of data to analyze, I will do that next week and let you guys know about the results.
Florian Festi wrote 09/05/2018 at 13:38 • point
Right! I should have noticed right away. But I only saw it after writing my comment and even then I did not fully get how it solves the issue. After thinking a bit more it is clear that the string is straight on the rollers and slanted in between.
Florian Festi wrote 09/04/2018 at 19:47 • point
Looks good. Your "spools" may be a bit short to take up the string walk. With each rotation the string will walk one string width as it is wound as a spiral. This can't really be avoided unless you roll up the string on top of itself. The way to deal with this is to make the rollers wide enough to allow the string to walk up and down without hitting the wall or walking off the roller.
But I have no real idea how much string movement you are expecting. May be the rollers are just wide enough already.
Tobiwan wrote 09/05/2018 at 10:11 • point
I was aware of that problem, so there are two "spools". They are configured like a lifting block, so there is no string walk :) Look closely at the photo.
