Shortly after the joy of 3D printing my first ever parts, I realised that I still havent been able to get my 64x32 OLED working with my Esp32. Maybe I just need to spend more time on it. Also having trouble trying to find a minimum configuration because I plan to take the Esp32 module off the dev board after programming but on the dev board there are two buttons "EN" and "BOOT". So for all this im going to use EasyEDA, a free online pcb and schematic creator, as well as JLCPCB for the manufacture of my boards.
Hopefully all goes well and I find a way to use an OLED with my esp32, in the meantime I need to see if I need a lens so I'll get an example sketch running on an arduino nano and wire everything else up to it then see if it works as expected, if not then I'll have a look at some old lenses I've collected.
