Game Boy Pi
The Game Boy Pi using a raspberry pi 3
In this Project I made the a Game Boy PI using the raspberry pi 3 and some other boards. I used a pic18f2550 as a HID joystick that controls the buttons, and PCM2707 board was add to obtain a high audio quality, the display used was the monitor for car 3.5". No GLUE used to assemble the case. Do not forget visit my blog, pic18fxx.blogspot.com
Rich text editor
prosto wrote 02/22/2019 at 12:30 point
this is better https://www.clockworkpi.com/
normal linux
but if You put normal procesor and fpga this will be great
pic18fxx.blogspot wrote 02/22/2019 at 14:42 point
Looks interesting the link, but that board does not support one USB joystick more, In my game boy pi I can connect a USB joystick or a keyboard, I have two USB ports available.
Mike Szczys wrote 07/03/2018 at 15:46 point
Beautiful job, I'd love to see more details on this! Do you have any plans to swap out the screws for something else? I wonder if there's a flat threaded insert that will look nice and allow you to secure the PCB from behind?
pic18fxx.blogspot wrote 07/03/2018 at 19:14 point
Hi Mike, I did not found other way to close the case and the pcbs, All the boards have screws, Was complicated the insertion of the raspberry pi 3, also I inserted the fan to raspeberry pi3.
But, I can play 1 hour only. the battery is not so good. All the compones that I used can be bought from ebay or aliexpress.
I have the PCB made in EAGLE. (armicrocontroller@gmail.com)
I will do a full teardown of this project.
Bye.
