'BOOM box' High voltage capacitor bank
The 'Boom box' is made out of 3 disposable camera's and delivers more than 2kV and about 10 amps.
The 'Boom box' is made out of 3 disposable camera's (you can use more than 3). I used the charge circuit from one camera and the capacitors from all 3 camera's and put them in parallel. Then I added a switch between the battaries and the charge circuit, a switch on the charge circuit itself to start charging the capacitors, and a switch after the capacitors to release the charge in one go (but I cannot recommend this to anybody because the switch welds itself together and gets stuck in one position. you would have to chose an appropriate switch that can handle the power). The 'Boom box' generates more than 2kV (max voltage my multimeter could read) and around 10 amps of current (biggest fuse it could blow with the thing).
STL-files can be found here: https://www.thingiverse.com/thing:2980012
Video:
boom box lid V1.stl
Standard Tesselated Geometry - 813.56 kB - 07/01/2018 at 18:57
Download
boom box base V1.stl
Standard Tesselated Geometry - 362.48 kB - 07/01/2018 at 18:57
Download
View project log
[deleted]
Brian Brocken wrote 04/21/2020 at 22:50 point
Hey man why do you spam my project with your advertisement. your comment has nothing to do with this project.
