To make the temperature between the foil plates and the peltier modules transfer more efficiently I added a thin layer of Arctic silver thermal paste in between.
A project log for SEBS (Seebeck Effect Buoy System)
This Buoy, with peltier modules attached, will use the Seebeck Effect to generate electricity using the ocean and the sun.
