To prevent water from accidentally being splashed onto the circuitry at the top I hot glued a clear cylinder covering from an old tape container to the top of the buoy. For the side of the covering that is facing the USB opening of the Boost Converter I cut a snug fit hole and in the process of trying to find some material to fill in the sounding to keep water from leaking in.
