Going fast now:
- LED footprint association fixed (5050 -> PLCC-2)
- Motor connector footprint association fixed (SMD Resistor -> Pin Header)
- Done component organization
- Redone component organization
- Net cleaned up (No more global tags for power)
- Track width modified for Vcc, GND, LED, +BATT and -BATT
- Removed SPI header
- Jumper type changed (NC -> NO)
- Jumper footprint association fixed (Pin Header -> Jumper Pad)
- GPIO0 and GPIO2 now uses separate wire
- LED current limiting resistor value changed
- Keepout zone added for ESP-12F
- Moved LED and other switched components away from antenna
- Added logo
- Added logo again
- Added branding
