This time the updates are slow but important.
- Added charging pad for ease of use (Read the warning on Cmts.User)
- Daughter board now has less copper to aid in signal loss reduction
- Added Noncommercial symbol
- Added graphic
- Component orientations are now marked with dots (Read the Cmts.User layer)
- Via stitching done (forgot to add that to Rev.9)
Daughter board has footprints but don't populate them! They are there as a decoration. You can see how the circuit makes absolutely no sense whatsoever, with it disregarding design rule like you drink water.
Now, all I have to do is have this tested somehow...
