Minor compatibility fixes here:
- Board outline has been redone properly to ensure 100% compatibility between other programs, no more ugly null component hacks here.
- Ornamental backplate has been redone too to ensure compatibility between other programs. Please note that all footprints on the board is only for show and you are not supposed to solder stuff onto it, but if you really want, you can do that, I suppose. It won't do anything, though.
- Spacer pins are added. Length is about 7.5mm and the black plastic piece must go inside the circuit board sandwich and soldered on both sides to add rigidity. Flush-cutting or dome of solder is required to prevent lacerations and damages to clothing and other delicate objects (such as human flesh). Silver or lead-free solder recommended to prevent leeching of lead metal.
- Logo position has been moved and resized.
- Typos has been fixed.
Some warnings for people with sensitive skin:
- Fiberglass board pieces near the mouse-bites or V-cuts (snap-off tab) can be sharp and strands may be irritating to skin. Sand and seal off the mouse-bites after it has been snapped off (if applicable).
- Lead poisoning may occur if leaded solder is used to solder places where water, humidity, salt or sweat can come into contact (such as outside perimeter of the circuit). If you feel nauseated or dizzy, remove the board immediately from the body and seek medical attention.
- Some board manufacturing processes may use non-lead-free processes and may have residual toxic chemicals. Wash each circuit board before wearing. (Isopropyl alcohol followed by dish soap will do, do this before soldering)
Torbjörn Lindholm
