Oops. Mistakes were made!
- CH340G footprint has been changed from SSOP to SOIC. This was a mistake carried over from using other USB-to-Serial converter chips. (Kids, sleep well. Else things like this will happen!)
- To fix the board if you happened to order the board before it was fixed, follow this diagram:
- Regulator placement has been adjusted.
- Crazy track found near C3, C4 and Y1 has been removed.
- Board outline near the right ear of the backplate has been corrected to allow drills to pass through.
- Batch number, date and vendor ID sections has been added for future use.
- Use that for inventory tracking and other features.
- The board outline has been rounded a bit. Now it shouldn't try to dig into your flesh. If it does, sand or shave off the sharp points with a box cutter, dremel tool, jeweler's file or sandpaper.
That'll do for this update.
