Hello all! I descided to ditch this headset , not because it was not going to work, , but because I shattered it into a million pieces when my saw blade caught the plastic and resin the wrong way. I did however continue to play with it and widened the body a great bit to see if I could like up 3 screens. I can do it however it looks " really big" as to how large the headset will be and I think it may not be aerodynamic at that point, so back to the drawing board. Here are the pics after it exploded and I cut the edges and spread them out to widen field of view.
I will measure out this work in progress and draw it as a STL that can be printed. I hope everyone finds that useful if you want to make a version for yourself.
