OK so this begins try 2, this is nor a hardware or implementation issue, I simply had a happy accident and found that another cheap headset has some features I could exploit. Of course in the name of open builds I want to use something easily attainable by the maker community, that being said I found the Lenovo Jedi Challenger game headset to have a set of optics that I think would work great to exploit! I found one as low as 45 dollars then offered $30 and the seller accepted it. Boom , replacement on the way. These are regularly 40-60 on ebay because the game itself is a bit of a flop for the price. This headset has a clear outside lens that I think I may be able to use in the end and would look better that piece work. I will still post 3D printable versions and VR goggle conversion instructions as well so everyone can join the fun!
