tests with a screen
A project log for Cyborg 360 Flir AR HUD Motorcycle Helmet
Worlds Largest 7" Diagnal personal AR display in a motorcycle helmet, see 360 degree view, smart interface. Flir, IR and Ultrasonic
josh-starnesJosh Starnes • 08/18/2018 at 03:24•0 Comments
Here are the first images , I need to do some trimming and work the settings , but this is the first images through the AR optics.  I need to reverse the background to be black so only important info overlays over the visual field. This image is not completely clear because the camera gets confused on what to focus on. Also my white shirt has a slight reflection, inside the helmet along with the black insides will eliminate this.
