Version 1 of the motherboard sled only considered mounting the main board, so the wifi and ssd are loose for now. I soldered some wires to two pads on the motherboard that when shorted turn on the machine. I'm using a toggle switch for now, but will replace it with some other more integrated switch when I design the enclosure.
