Coil Placement:
Place the coils inside the Coil Holder/ Stator. There are three pins inside which the coils will sit.
The "IN" and "OUT" of the coils where the winding started and ended need to the placed in the appropriate notches. These will help identify how the coils would be wound.
Coil Housing Preparation:
Glue gun the coils in place.
Apply glue to the edges of the coil housing
The coil housing is covered with the 3DP Housing Cover
