![](https://cdn.hackaday.io/images/2599231531722855542.jpg)
![](https://cdn.hackaday.io/images/7566891531722897149.jpg)
This phase too easy just you have to fix the hand power torch in the shoes. After fixing the torch result would be like this.
A project log for Battery Charging Through Shoes
A Project About Power Generation With The Movement Of Steps.
