Change the input PWM signal to another PWM signal output with an Encoder
GitHub repository this code: https://goo.gl/93mw2v
I thinking to create a PCB for my project.
A lot of FabLab or Hacker Space has a home made laser cutter, and i suppose they have the same problem for setting the ( PWM ) power for the cut.
Stay tune!
View project log
Yes, delete it Cancel
You are about to report the project "PWM to PWM", please tell us the reason.
