The development phase started long time ago. Initially I wanted to use an esp8266 to manage a display and input sensors. It had WiFi and it could be perfect for what I needed. I started to design a board around the ESP-12 module but the ESP don't have enough gpios for my needs. (Displays uses SPI busses and a lot of lines to control)
At that point I was starting to design a proper board size, here in italy the electronic stuff is inserted into 503 boxes. The sizes are small but not that small!
