I'm testing out the firmware for the baseboard. Right now I have basic UART bridge (I have only tested the TX from Master to Slave) and the IO Expander functions. Interrupts are not implemented yet. I'm working on PinChangeInterrupts for the IO Expander.
This is part of the sketch of the master:
#include <Wire.h>
void setup() {
Wire.begin();
Wire.beginTransmission(42); // Transmit to device #42
Wire.write(0x02); // Write to the port direction register
Wire.write(0xF0); // Register data
Wire.endTransmission(); // Stop transmitting
delay(500); // Some delay to make is easy to see on the logic analyzer
Wire.write(0x07); // Write to the TX buffer register
Wire.write("HELLO!\n"); // Register data
void loop() {
bool changed = false;
uint8_t byte_t = 0;
unsigned long currentMillis = millis();
// See "Examples > Blink without delay" to understand how this work
if (currentMillis - red_millis >= red_int) {
red_millis = currentMillis;
// Instead of writing the pin we toggle a bit on the register
bitWrite(byte_t, 1, !state_red);
state_red = !state_red;
changed = true;
if (changed) {
Wire.write(0x04); // Port status register
Wire.write(byte_t); // Port data
Nicolò
