As described above, I needed a PSU for another project and only had one potentiometer. I added a 7805 for it's common use but now have an elegant little PSU with 2-17V variable and 5V linear output.
A project log for Low cost var. out PSU with laptop adapter
A common ground PSU with 2 to 17V variable or 5V linear output using a laptop power adapter and an external multimeter
