I just made a few last-minute fixes, and ordered the boards for DirtyPCBs. Their shipping seems to be working again, and I want to support them for not caring about how your project is panelized and how many "distinct" designs there are.
I decided to use white PCBs again, mostly because the matrix's outside is white too, and because I found white battery holders on Aliexpess. I used a cheap shipping option, so it will be a few weeks — which is totally fine by me, because I'm going to the Europython conference next week anyways.
I also added those tiny squares there, which I'm going to glue under the USB plug. Since the PCB is 1.2mm thick, this will get me to the required 2.4mm thickness.
deʃhipu
May the flux be with you!
Thanks!
