You might wonder how you reconstruct an image with AC current. Well it's exactly the same way as you do in a cat scan.
By sending current through every combination of electrodes, you measure the differences at the receive end and add up all the signals similar to the picture above. The addition of all these paths adds up to the image again. This technique is called back projection, and you can use the radon transform to do it.
