15 July. Working on software – initial version now complete and started testing / debugging
Set up breadboard with Arduino, voltage dividers and current shunt amplifier, and connected with the SZBK01. The breadboad modeel uses a schottky diode instead of the MOSFET diode at this stage to reduce build time.
