Using tof based lasers, arayed on moton tracking gimbals, attached to multi channel mixer/synthesis (midi), allow each perforner to control up to 8 (current system has 8 channel per person) instruments ( 6 octaves X 8 key positions ).
The motion tracking is based on AI learning of predictive movement to position the. time of flight laser at the pont of triger on the performer's body for that channel, key, octave sequence. Then all points for all sequences centrally controlled to display a simulation on screen with multi-channal sound output. (Full AC67 and Dolby surround capable) for sound boarding.
