I managed to finish the design of the so called console, one of the human-machine interfaces of the robot. It consists mainly of a 3.2" touch TFT, two 16 ways capacitive touch keypads based on the TTP229 capacitive sensor with accurate sensing of up to 16 points, an Arduino Mega, a Mega touch TFT shield and some 3-D printed parts:
Assembly
To have still access to the already occupied pins or not used pins on the Arduino Mega respectively the TFT shield I soldered angle male headers onto the according pins:
PCB's wired and mounted:
Later the two PCB's will be covered by a custom printed Lexan label done by a local printing shop and designed by myself in Inkscape, now only paper label for testing:
Got further 3-D printed parts today and mounted TFT and Arduino Mega:
An Adafruit precision DS3231 RTC is mounted on its back:
Got the labels and tested the keyboard. It works like a charm even the capacitive pads are covered by the label, which has a thickness of 0.18 mm. Really an easy and reliable solution to build a touch keyboard. If you miss haptic feedback, you can add a vibration motor or a piezo actuator underneath the PCB's or in the enclosure of the keyboard:
