Parametric!
A project log for P1 - Buddha Tape feeder
3D printable Pick and Place tape feeder for the Arcus-3D-P1.
masterofnullMasterOfNull 07/29/2018 at 01:150 Comments
Reworked all the code so you can change the offsets, gear ratios, sprocket and ratchet tooth count, thickness, and even the cover spool direction on the fly and everything scales.
I also moved the return spring up to the lever handle, and changed the connecting rod to be piano wire.
The whole thing is a lot sturdier, but I gained .5mm of thickness in the process and we are now at <tape width> + 4mm,.  Good thing is now, if you want, you could just turn that down as a variable.  :)
I've uploaded the updated source.
Time to print this thing again.
Rich text editor
