We wanted to publish the dev board we made for the WM8750BL audio codec IC.
Design files: 20180702 - audio codec board
Datasheet: WM8750BL_v4.1-1131666.pdf
Overview (from the datasheet)
The WM8750BL is a low power, high quality stereo CODEC designed for portable digital audio applications.
The device integrates complete interfaces to stereo or mono microphones and a stereo headphone. External component requirements are drastically reduced as no separate microphone or headphone amplifiers are required. Advanced on-chip digital signal processing performs graphic equaliser, 3-D sound enhancement and automatic level control for the microphone or line input.
Features:
- Stereo / Mono Microphone Interface
- 400mW Speaker Driver (mono)
- Headphone Driver
- Digital Graphic Equaliser
- Audio sample rates: 8, 11.025, 16, 22.05, 24, 32, 44.1, 48, 88.2, 96kHz
- 5x5x0.9mm QFN package
- 1.8-3.3V Supply
The design is in PADS. Everything is there to fabricate it yourself. BOM, gerbers, PDF schematic + PADS schematic and layout.
Currently the audio quality is not very good. There's a good chance that's due to the digital and analog ground planes not being separated.
Pinout:
Pin 1: GND
Pin 2: VCC
Pin 3: SDA
Pin 4: SCL
Pin 5: ADCDAT
Pin 6: WS
Pin 7: BCLK
Pin 8: DACDAT
![WM8750BL Breakout Board](https://cdn.hackaday.io/files/1598116837353824/WM8750BL_top.png)
