A multi-thread enabled N-Queens benchmark for hardware running Python.
Follow the instructions https://www.python.org/getit/
You can find the repository here: https://github.com/lemariva/N-Queens-Problem
The repository includes a file "temperature.py". This is coded to get the temperature (CPU & GPU) of a Raspberry Pi. If you are not using a Raspberry Pi, you need to modify this file to get the hardware temperature or just delete it.
