FPGA Device
- Stratix II GX EP2SGX30CF780CSN Device
- 30K Programmable Logic Elements
- M4K RAM blocks (128×36 bits) - 144
- M-RAM blocks (4K×144 bits) - 1
- Transceiver data rate 600 Mbps to 6.375 Gbps
Configuration and Debug
- Serial Configuration Device EPCS16N on FPGA
- JTAG
Expansion I/O
- 2 x SDI TX over GENNUM GS2978
- SDI RX over GENNUM GS2974A
- 10-pin GPIO Header
- 2x10 header
Display
- DVI RX over Sil7181 (no datasheet)
Switches, Buttons, LED, and 7-Segments
- 3 LEDs
- 8 Slide Switches
Power
- 12V DC input
Limitations
- Quartus II Web Edition - 11.0sp1 -- ATTENTION. There is no complete certainty!
- Quartus II Subscription Edition - 13.0sp1
- It is impossible to find documentation on the Sil7181 chip.
Block Diagram
IC list:
U1 GS2974A 4483E3 1052 GENNUM
U2 IDT Q53VH25 7QG Z41104K
U3 EL4511CUZ B1047BF4T
U4 Silicon Image VastLane Sil7181CMHU-0 Q3F619.1-18 1111 AD01KX2
U5 551MLF 1221868 1103
U6 664G03LF 1415966 1112
U7 ZGAH
U8 M 834U 0496
U9 (5-PIN)
U10 (5-PIN)
U11 EP2SGX30CF780CSN
U12 EH11A 109N77
U13 L1BH
U14 527R-01LF 1814763 1114
U15 EPCS16N 9911EV5 PHL101
U16 431 (3-PIN)
U17 6549CBZ V1052TS
U501 EH11A 109N77
U503 GS2978 4371E3 1048 GENNUM
U504 GS2978 4371E3 1048 GENNUM
Pinout
EP2SGX30_sdi_hack.v
module EP2SGX30_sdi_hack ( input REFCLK0_B13, //148.5 MHz output GXBTX_0, output GXBTX_1, output SD_HD, output [2:0] LED, input [7:0] SW, output [15:0] DEBUG ); endmodule
EP2SGX30_sdi_hack.qsf
set_location_assignment PIN_J1 -to REFCLK0_B13 set_location_assignment PIN_J2 -to "REFCLK0_B13(n)" set_location_assignment PIN_E4 -to GXBTX_0 set_location_assignment PIN_E5 -to "GXBTX_0(n)" set_location_assignment PIN_C4 -to GXBTX_1 set_location_assignment PIN_C5 -to "GXBTX_1(n)" set_location_assignment PIN_C28 -to DEBUG[0] set_location_assignment PIN_D28 -to DEBUG[1] set_location_assignment PIN_D27 -to DEBUG[2] set_location_assignment PIN_E28 -to DEBUG[3] set_location_assignment PIN_F28 -to DEBUG[4] set_location_assignment PIN_F27 -to DEBUG[5] set_location_assignment PIN_G28 -to DEBUG[6] set_location_assignment PIN_G27 -to DEBUG[7] set_location_assignment PIN_H28 -to DEBUG[8] set_location_assignment PIN_J28 -to DEBUG[9] set_location_assignment PIN_J27 -to DEBUG[10] set_location_assignment PIN_K28 -to DEBUG[11] set_location_assignment PIN_K27 -to DEBUG[12] set_location_assignment PIN_L28 -to DEBUG[13] set_location_assignment PIN_M28 -to DEBUG[14] set_location_assignment PIN_M27 -to DEBUG[15] set_location_assignment PIN_B10 -to SW[0] set_location_assignment PIN_A10 -to SW[1] set_location_assignment PIN_C8 -to SW[2] set_location_assignment PIN_A9 -to SW[3] set_location_assignment PIN_B8 -to SW[4] set_location_assignment PIN_A12 -to SW[5] set_location_assignment PIN_A7 -to SW[6] set_location_assignment PIN_A8 -to SW[7] set_location_assignment PIN_AB9 -to LED[0] set_location_assignment PIN_AC9 -to LED[1] set_location_assignment PIN_AD10 -to LED[2] set_location_assignment PIN_AH7 -to SD_HD
Pulse and Square wave Generator.
