For the detailed instruction and program, please click here.
If you press the button, the roulette starts rotating. If you press again, the roulette stops rotating and beeps!
It is only wired speaker and button.
The pin no of wired are written on program.
button = obniz.wired("Button", {signal:6 , gnd:7 });
speaker = obniz.wired("Speaker", {signal:0 , gnd: 1});
On HTML, you can use "css transform". For example , this is the code of rotate image 90 degree.
document.getElementById("roulette").style = "transform:rotate(90deg);";
To start and stop rotate slowly, add a var speed
for rotate degree per frame.
let speed = 0;
let deg = 0;
function rotate(){
deg += speed;
document.getElementById("roulette").style = "transform:rotate("+deg+"deg);";
setInterval(rotate,10);
Do you want to beep on the roulette no change? With this, you can beep on 440Hz 10ms.
speaker.play(440); await obniz.wait(10); speaker.stop();
This is how to know on change of roulette no.
if( Math.floor((deg + speed) / (360/7.0)) - Math.floor(deg / (360/7.0)) >= 1){
onRouletteChange();
So, this is the code of rotate and beep.
let speed = 0;
let deg = 0;
function rotate(){
//on change value
onRouletteChange();
deg += speed;
async function onRouletteChange(){
if(!speaker){return;}
speaker.play(440);
speaker.stop();
