How to use the HCC MOD.
A small, easy to solder, surface mount, Arduino module. Start designing your own custom PCBs!
I have just released the next project, its a small gaming device and controller called the MOD_Boy. Check it out!
Here is the first of many projects using the HCC Module. I will be releasing them periodically during the Kickstarter.
DIY RGB Cherry MX Keypad.
The project has now launched on kickstarter!
https://www.kickstarter.com/projects/idlehandsdev/hcc-mod-ready-to-solder-arduino-module
I hope these continue production after the Kickstarter. This could be huge. I regret I found them late, after the kickstarter closed. I'd love to but a dozen or two...
