HCC Module
A small, easy to solder, surface mount, Arduino module. Start designing your own custom PCBs!
The HCC Module is a small, Arduino compatible, SAMD21G18A microncontroller module. It is designed to be surface mounted onto your custom PCBs. Its a stepping stone from using a dev board to make your project, to making a full on custom PCB. It will come pre-loaded with a bootloader, so all you need is a USB connection and some power!
How to use the HCC MOD.
View all 3 project logs
Service Computers, LLC wrote 10/04/2018 at 19:35 • point
I hope these continue production after the Kickstarter. This could be huge. I regret I found them late, after the kickstarter closed. I'd love to but a dozen or two...
PointyOintment wrote 07/24/2018 at 07:59 • point
What does HCC stand for?
