GET ONE HERE: http://kck.st/2Mo4iym
DISCORD GROUP => https://discord.gg/HfJhd2S
Before we get into the project's details, I would like to invite you to join our Discord group where we chat about hacking, electronics, IoT, and much more => https://discord.gg/HfJhd2S
What you can do with it (just some ideas....)
Guests at home: Your friends are visiting you at home? No problem, just setup your Kortex Xtend Lite as a free open WiFi access point and let your friends connect without them knowing your WiFi password.
Deploy a WiFi drone: You can take your WiFi connectivity to the air by simply attaching your Kortex Xtend Lite to a drone. You can use it for allowing IoT sensors located at a high altitude to connect to the internet in order to upload the recorded data to a server (e.g: temperature, humidity, pressure).
Scan AP's with a drone: You can also use it to scan your neighborhood access points by simply flying your drone near the place you want to get info from. Imagine you want to hack your angry neighbor WiFi (just kidding... don't do it), but your computer doesn't detect the AP due to the large distance between your home and the AP you want to scan. The solution would be flying your drone with the attached repeater, and from your computer (already connected to the repeater attached to the drone) running "snet" command in order to get the access point name, ip address and mac address.
Your drone should be on air at least 15min. If the drone moves to too far from the AP, you could fail at sending commands, and also while receiving data. Remember that this repeater only provides information about the network (and of course other great features), and it cannot do things a computer does, so when I say hacking, that means from your computer, the repeater is only a little "spy"
Protect your connected devices: The advantage of using this NAT repeater is the IP masquerading feature that protects your devices (computer, IoT sensors, etc...) identity by implementing a network address translation procedure that gives your devices a unique private IP address hidden behind a single public IP address (repeater IP address), so you can keep a bunch of devices hidden from hackers.
Deploy aerial WiFi zones with drones (mesh) *not tested yet: Do you want to provide WiFi to a large area? That's possible if you can get a bunch of drones and attach to them another bunch of Kortex Xtend Lite repeaters set to "mesh" mode. If you fly the drones, automatically the repeaters will form a mesh network and you'll be able to provide WiFi connectivity to your clients (IoT sensors, neighbours, etc....). Remember that many factors like trees, houses, weather and distance can cause WiFi bandwidth to go down, and eventually, if you increase the number of repeaters (up to 8) the available bandwidth will almost disappear, so please keep that in mind :)
Capture data from connected clients: In order of being able to capture connected clients data, firstly you must set the repeater as an open WiFi access point (see *commands list, documentation and tutorials - up)
Once you make sure someone is connected to your Kortex Xtend Lite (by running "show" command) from your console or Telnet terminal start a monitor service by running "monitor on [portno]"
This service mirrors the traffic of the internal network in PCAP format into a TCP stream. With a "netcat [external_ip_of_the_repeater] [portno] | sudo wireshark -k -S -i -" from a computer in the external network you can now observe the traffic in the internal network in real time. Use this to observe with which internet sites your clients are communicating.
Technical Data
On the bottom side, there’s a reset button for restarting the ESP8266, and an IPEX cable that connects the SMA connector to the ESP8266 in order to maximize transmission range.
Comes fully assembled and tested, with the firmware uploaded and a USB bootloader that lets you quickly use it with the Arduino IDE serial monitor or any other similar software. It's based on the implementation of a WiFi NAT router on the ESP8266-07S.
It allows packet filtering firewall with ACLs, traffic shaping, port mapping, packet sniffing, an MQTT management interface, power management, in/out data management, and so on. It also includes support for the implementation of ENC28J60 Ethernet connection, which would require an additional hardware component, however, this feature as not been tested or debugged yet, which means it could have some bugs. Next version releases will include updated firmware and documentation.
Specs
Features
- NAT (Network Address Translation)
- Traffic Shaping
- Port Forwarding
- Packet Sniffing
- Port Mirroring (internal networks) to TCP stream
- IoT ACL Firewall
- KRACK Attack Invulnerability
- Static Routing
- Mesh Networking Mode
- Bitrate Limiting
- MQTT Device Management
- Power Management
- Battery powered
- Low Power Consumption
- Long Range Transmission*
- On/Off Power Switch
- Reset Button
- Hardware Factory Reset Mode
- Small size/weight
Mesh Networking Feature: A mesh network is a local network topology in which the nodes connect directly and dynamically to as many other nodes as possible and cooperate with one another to efficiently route data from/to clients. This can be done without any problems with Kortex Xtend Lite repeaters, which allows you to setup multilayering NAT structures, and of course, the more layers you add, the available bandwidth will decrease.
Each repeater configured in automesh mode will automatically offer a WiFi network on the access point with the same SSID/password as it is connected to, and it will first search for the best other access point to connect to, and this is the one which is closest to the original WiFi network and has the best signal strength.
MQTT Device Management Feature: Kortex Xtend Lite has a built-in MQTT client, which allows you to transform your repeater into an IoT device that can monitor power (load), connected stations, bitrate, etc...
Port Mirroring Feature: This amazing feature mirrors the traffic of the internal network in PCAP format to a TCP stream. From any computer in the external network you can now observe the traffic in the internal network in real time. This means you could observe on with which sites your users are communicating, or even steal packets.
Why did you make it?
Actually, this board was made for my baccalaureate high school project, since I'm an 18-year-old electronics & programming enthusiast who loves creating new "things" that improves and facilitates science and research. It took me almost a year to design it along with another board, make the prototypes, test, and build the final version and I think this was a great experience for me since this is my first high "complexity" electronics project I ever made. Mainly I use Kortex Xtend Lite to connect my Kortex A1 IoT environment devices to the internet.
