Do you wanna feed your pets from outdoor? I have made a feeding machine which can be controlled on the browser using smartphone.
Cut pipes and prepare the screw. I made a screw by using 3D printer. Then, connect screw to a motor. and put them into a box.
Connect servo motor to obniz.
io0: GND,
io1: VCC,
io2: signal
Then power up your obniz.
Write codes below and put food into the bottle. Food will come out from the pipe.
View all 4 instructions
[SF] Pigeon Kicker -- AkA James Ryan
Cristian
Dharshan Bashkaran Latha
Foxmjay
Yes, delete it Cancel
You are about to report the project "Feeding cat remotely using smartphone with obniz", please tell us the reason.
