Here is a picture of the assembled mixer:
The white wires are signal inputs for each different channel. The blue wire goes to the common
ground. This mixer assumes all channels share a common ground.
The component values were chosen based on what I had lying around.
Currently waiting for the a shipment of the following potentiometers in order to populate the voice cards.
