The proper pots arrive. The next board revision will definitely need more space between them.
These are 10K and will be used in a second voice board.
Some 100K pots also came in the mail and will be used soldered in a voice board that will function as an 8 channel passive mixer.
One board, multiple uses.
![](https://cdn.hackaday.io/images/725751536518878288.jpg)
![](https://cdn.hackaday.io/images/9069781536518890960.jpg)
Instagram post:
