I've made a lot of posts in this project and the Hackaday.io inteface doesn't seem to allow creation of an index. So here's a summary of logs so far:
- 3D Printed Enclosure (written in OpenSCAD)
- "sysinfo" - A System Information Server
- "piHole" - A Text-to-Speech Message Server
- "Blinkter" - A Neopixel Strip Controller
- "VoiceBox" - Google Assistant Interface
- Adding Streaming Radio to "VoiceBox".
- Adding a Pomodoro Timer to "Blinkter"
- WiFi Controlled Accessories With the ESP8266
In each case you should look at the logs before and after that linked for context and follow-up.
I must admit that I'm stalling a bit. I have lots of ideas for extending the project, but all the worthwhile ones are contingent on building a fresh Raspbian image with fully up-to-date Google API libraries and Numpy. I should also make sure that everything runs on Python3 (before f-strings break library compatibility again).
The next post will probably be a long, rambling, open-ended log of my steps in building the new image, I'll try to tidy and summarize in a later post, once everything's (hopefully) working.
Python 2 vs. Python 3 [Dramatized]
TM
