I have made a small change with the fixed USB port names. I have now set the names to the physical USB port and not to the USB-Serial-Converter.
With this setting every perforated plate (which is used for the targets) gets its own USB-Serial-Converter. It is also much better to put one USB extension cable that is shielded from the Raspi to the target, than like with the old setting 3 loose wires for Tx, Rx and GND and with no shielding.
Nikola
