Ever been looking for a development board based on the popular STM32F103C8 micro controller, that not only features the essentials for developing with Cortex M3 MCUs but also comes in a convenient shape? Then look no further!
Meet the ARMed STICK - a Cortex M3 development board in the convenient size of a USB stick that provides the following features:
- Powered by the popular STM32F103C8T6 micro controller, offering 64KB of flash memory + 20KB of RAM
- External 8MHz crystal that can be used to drive the STM32's HSE clock
- External 32.768 kHz crystal that can be used to drive the STM32's RTC / LSE clock
- A reset tactile button
- Boot selection jumpers for being able to easily change the boot mode when programming the MCU
- A UART breakout header for programming the MCU via its serial boot loader
- SWD breakout header
- A USB A connector to power the board off of a USB port (incl. connected USB data lines w/ an appropriate pull-up resistor value on USB_DP of 1.5K)
- A VCC indicator LED for indicating the presence of 3V3
- A user-programmable LED on pin PB0 (PWM)
- 24LC08 EEPROM (connected to I2C, incl. appropriate pull-up resistors)
Pattern Agents
arturo182
ian-l-johnson
please share the project
