Full adder
A project log for ALU in DCTL technology
A full ALU, capable of ADD, SUB and all logic functions, with only 12 transistors
roelhroelh • 08/04/2018 at 20:22•0 Comments
The Falstad simulation of the full adder has two parts. The first part creates the input signals for the adder:
There are switches to change the input signals A and B, and the Carry input signal. There are also 3 LED's to check the input values. At the right side you see the 3 created signals CY-IN, A and B, and an inverted version from B.
The second part is the actual adder:
This is actually an implementation of a classic adder design.  The following picture shows the function of the transistors:
