Added most stack instructions
A project log for Plasma Cortex: open source CPU in VHDL!
This CPU was designed for efficiency and simplicity, while staying an effective and useful design.
dylan-brophyDylan Brophy 08/05/2018 at 23:222 Comments
I needed to re-add the stack instructions to make the CPU work.
As some saw in the HDD crash project log on the #DEXT Meteor project, I lost the VHDL code for the latest version of the Plasma Cortex processor.  That version had most of the instructions already implemented, and the old version I had a backup of did not have all those instructions.  Today I added the four main stack instructions for my CPU:
CALL address
PUSH register
POP  register
ADD  SP, 32 bit constant
You notice no RET instruction?  The Plasma Cortex allows access of all registers the same way, so these are actually valid instructions:
MOV  PC, 0xDEADBEEF ; alias of JMP 0xDEADBEEF
POP  PC ; alias of RET
PUSH PC ; unique instruction
MOV  AX, PC ; another unique instruction
The programmer has full control over the program counter, so the assembler just converts RET instructions to POP PC.
There are no interrupts *yet*, so no IRET or anything like that.  I actually do not plan on having a special return instruction for the Plasma Cortex because I feel it is unneeded.
[edit] Just realized I still need to add these instructions:
MOV [sp+16 bit offset], general purpose register
MOV general purpose register, [sp+16 bit offset]
Those are for the C compiler's local variables.  Those instructions greatly speed up C programs running on the Plasma Cortex.
That's all for now, thanks for reading!!
Rich text editor
Ed S wrote 08/09/2018 at 16:14 point
Losing your work is a shock... but are you finding it relatively easy to redo? Is it even coming out a little cleaner the second time?
Dylan Brophy wrote 08/09/2018 at 17:55 point
cleaner the second time!  Ya, hardest part was loosing a game I made...  really sad.
