Here are the Github links for the source code used in this project. If you want to go a-hacking, you will most likely want the Launcher firmware. The bootloader code is included for those who are interested, but it's not needed unless you are starting out with a factory-fresh chip. After the initial bootloader flashing, all further flashing of firmware, etc is done either through Arduino, or better yet - by dropping a UF2 file onto the USB device itself. (Double click reset to open the USB firmware drive for drag & drop flashing)
Launcher Firmware Source Code (Arduino Sketch)
https://github.com/electronrancher/sam-fusee-launcher
Bootloader Source Code
https://github.com/electronrancher/uf2-samdx1
